Home
Help
Search
Login
Register
SlickEdit Community
SlickEdit Product Discussion
SlickEdit®
Deleting all blank lines in a file
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Deleting all blank lines in a file (Read 8891 times)
cdrdash
New Community Member
Hero Points: 0
on:
September 25, 2007, 06:41:36 PM »
Is there a simple way to delete all blank lines in a file with SlickEdit?
Logged
Senior Community Member
Hero Points: 292
Re: Deleting all blank lines in a file
Reply #1 on:
September 25, 2007, 07:19:42 PM »
Yes - e.g. by simply search'n replace them using a regex like that:
'c/^[ \t]*\n//@rp*'
on SE cmdline.
Logged
SlickEdit Team Member
Hero Points: 130
Reply #2 on:
September 26, 2007, 01:11:09 PM »
There is a ready-made command
delete-blank-lines
written for the Emacs emulation, but can be bound to a key in any emulation or used on the SlickEdit command-line any time.
Logged
Hero Points: 292
Reply #3 on:
September 26, 2007, 01:40:33 PM »
Good to know - that's much more convenient. Hopefully I'll remember next time I need it.
Although the regex method is more flexible (omit hidden lines, limit to selection etc.)...
Thanks
Logged
Hero Points: 130
Reply #4 on:
September 26, 2007, 01:57:09 PM »
Oops, just noticed the "all" in the Subject line.
delete-blank-lines
only deletes all the blank lines from the current line. It does not do the entire file, so the a regular expression search and replace is the right way to do the entire file.
Logged
bogedo
Community Member
Hero Points: 0
Reply #5 on:
February 26, 2023, 07:02:51 PM »
aware that an old topic is being dug up but this is still relevant all these years later.
's solution still works but it would be great if we had a built in function to delete all the blank lines in a file.
Logged
Hero Points: 347
Reply #6 on:
February 27, 2023, 05:50:13 AM »
If you expect to be able to reverse the operation in one step then it's not trivial unless you do it by saving a copy of the file before you do the delete. I can't imagine anyone wanting to delete all the blank lines from a software source file - is that what you want this for or is it some other kind of file?
Logged
Tim Kemp
Hero Points: 92
Reply #7 on:
March 04, 2023, 05:12:01 AM »
I've never needed to do it to a source code file, but I have done it regularly when I'm formatting data for a variety of things. Often the data ends up in a source code file.
Logged
mwb1100
Hero Points: 13
Reply #8 on:
April 10, 2023, 06:39:26 PM »
A variation that I would use more often than deleting all blank lines is to "collapse" (or squeeze) blank lines (including those that have only whitespace characters) to a single blank line. I'm pretty sure a regex to do this wouldn't qualify as simple.
Currently I use a simple bash function. I guess I should figure out how to do this as a Slickedit macro:
Code:
[Select]
squeeze ()
sed 's/[ \t]*$//' "$1" | cat --squeeze-blank
Logged
Hero Points: 153
Reply #9 on:
April 11, 2023, 05:34:07 PM »
From the SlickEdit command line,
delete-search /^$/r
would do it. That's using SlickEdit regular expressions, convert to whatever kind you're the most comfortable with, allow for whitespace to be fancy if you wish.
https://youtu.be/P6WDBg4C2bY
Logged
Print
Pages: [
1
Go Up
« previous
next »
SlickEdit Community
SlickEdit®
