Author Topic: Color schemes  (Read 73066 times)
  • Hero Points: 292
Re: Color schemes
« Reply #15 on: November 22, 2007, 01:17:40 PM »
@rsadeh:
Note that the '<VSLICKCONFIG>/uscheme.ini' contains all user defined color schemes where <VSLICKCONFIG> is your config directory. (BTW: There is also a default env. variable with this name set by SE on startup.)
See 'Help>About' where your config directory is located. I'd propose to leave the product default 'vsscheme.ini' as it is. It's also overwritten whren installing the next upgrade/version.
If you didn't change the default color scheme yet 'uscheme.ini' might not even be exisiting. In this case you can simply download one of the great 'uscheme.ini' files posted here to the config dir. After that you should be able to select one of the new schemes.
@Ding:
I'd prefer 'Water Color' too - but I'm used to my own color scheme ... :)
madmuggle
Re: Color schemes
« Reply #16 on: November 28, 2007, 09:14:25 PM »
Here's my usual one... sometimes I switch to a light one for a bit, but prefer dark backgrounds, easier on my eyes since I'm usually up coding all night.  Stupid deadlines. :)
Ding Zhaojie
  • Hero Points: 37
Re: Color schemes
« Reply #17 on: June 04, 2008, 01:43:49 AM »
Inkpot (port from VIM)  8)
[Inkpot]
CFG_WINDOW_TEXTfg=0xADBECE
CFG_WINDOW_TEXTbg=0x211C18
CFG_WINDOW_TEXTff=0x0
CFG_COMMENTfg=0x8ACE
CFG_COMMENTbg=0x211C18
CFG_COMMENTff=0x0
CFG_KEYWORDfg=0xEF8A84
CFG_KEYWORDbg=0x211C18
CFG_KEYWORDff=0x1
CFG_LINENUMfg=0xCE8A8C
CFG_LINENUMbg=0x211C18
CFG_LINENUMff=0x1
CFG_NUMBERfg=0x6BAEF7
CFG_NUMBERbg=0x211C18
CFG_NUMBERff=0x1
CFG_PPKEYWORDfg=0x949242
CFG_PPKEYWORDbg=0x211C18
CFG_PPKEYWORDff=0x1
CFG_STRINGfg=0x8CCFFF
CFG_STRINGbg=0x424142
CFG_STRINGff=0x0
CFG_PUNCTUATIONfg=0x8CCFFF
CFG_PUNCTUATIONbg=0x211C18
CFG_PUNCTUATIONff=0x1
CFG_LIBRARY_SYMBOLfg=0x8CCFFF
CFG_LIBRARY_SYMBOLbg=0x211C18
CFG_LIBRARY_SYMBOLff=0x1
CFG_OPERATORfg=0x8CCFFF
CFG_OPERATORbg=0x211C18
CFG_OPERATORff=0x1
CFG_USER_DEFINEDfg=0xADBECE
CFG_USER_DEFINEDbg=0x211C18
CFG_USER_DEFINEDff=0x1
CFG_FUNCTIONfg=0xFF8AFF
CFG_FUNCTIONbg=0x211C18
CFG_FUNCTIONff=0x1
CFG_SPECIALCHARSfg=0xADBED1
CFG_SPECIALCHARSbg=0x211C18
CFG_SPECIALCHARSff=0x0
CFG_HEX_MODE_COLORfg=0x6BAEF7
CFG_HEX_MODE_COLORbg=0x211C18
CFG_HEX_MODE_COLORff=0x0
CFG_ATTRIBUTEfg=0x8CCFFF
CFG_ATTRIBUTEbg=0x211C18
CFG_ATTRIBUTEff=0x1
CFG_UNKNOWNXMLELEMENTfg=0xD682C6
CFG_UNKNOWNXMLELEMENTbg=0x211C18
CFG_UNKNOWNXMLELEMENTff=0x1
CFG_XHTMLELEMENTINXSLfg=0xEF8A84
CFG_XHTMLELEMENTINXSLbg=0x211C18
CFG_XHTMLELEMENTINXSLff=0x1
CFG_CURSORfg=0x424142
CFG_CURSORbg=0xFF8A8C
CFG_CURSORff=0x0
CFG_CLINEfg=0xADBECE
CFG_CLINEbg=0x292C29
CFG_CLINEff=0x0
CFG_INSERTED_LINEfg=0xCEFFFF
CFG_INSERTED_LINEbg=0x316D31
CFG_INSERTED_LINEff=0x1
CFG_MODIFIED_LINEfg=0xCEFFFF
CFG_MODIFIED_LINEbg=0x8C6931
CFG_MODIFIED_LINEff=0x1
CFG_NOSAVE_LINEfg=0x292C29
CFG_NOSAVE_LINEbg=0x292C29
CFG_NOSAVE_LINEff=0x1
CFG_SELECTED_CLINEfg=0xEFEFEF
CFG_SELECTED_CLINEbg=0x8C4D4A
CFG_SELECTED_CLINEff=0x0
CFG_SELECTIONfg=0xEFEFEF
CFG_SELECTIONbg=0x8C4D4A
CFG_SELECTIONff=0x0
CFG_FILENAMEfg=0xBDBABD
CFG_FILENAMEbg=0x5A3C39
CFG_FILENAMEff=0x1
CFG_HILIGHTfg=0x313031
CFG_HILIGHTbg=0x638ACE
CFG_HILIGHTff=0x1
CFG_BLOCK_MATCHINGfg=0x424142
CFG_BLOCK_MATCHINGbg=0x8CFF8C
CFG_BLOCK_MATCHINGff=0x1
CFG_INC_SEARCH_CURRENTfg=0x313031
CFG_INC_SEARCH_CURRENTbg=0x638ACE
CFG_INC_SEARCH_CURRENTff=0x1
CFG_INC_SEARCH_MATCHfg=0x313031
CFG_INC_SEARCH_MATCHbg=0x638ACE
CFG_INC_SEARCH_MATCHff=0x1
CFG_SYMBOL_HIGHLIGHTfg=0x313031
CFG_SYMBOL_HIGHLIGHTbg=0x638ACE
CFG_SYMBOL_HIGHLIGHTff=0x1
CFG_MESSAGEfg=0x80000008
CFG_MESSAGEbg=0x80000005
CFG_MESSAGEff=0x0
CFG_STATUSfg=0x80000008
CFG_STATUSbg=0x80000005
CFG_STATUSff=0x0
CFG_CURRENT_LINE_BOXfg=0x424142
CFG_CURRENT_LINE_BOXbg=0xC0C0C0
CFG_CURRENT_LINE_BOXff=0x0
CFG_LINEPREFIXAREAfg=0xCE8A8C
CFG_LINEPREFIXAREAbg=0x292C29
CFG_LINEPREFIXAREAff=0x0
CFG_PREFIX_AREA_LINEfg=0x424142
CFG_PREFIX_AREA_LINEbg=0x424142
CFG_PREFIX_AREA_LINEff=0x0
CFG_VERTICAL_COL_LINEfg=0x424142
CFG_VERTICAL_COL_LINEbg=0x808080
CFG_VERTICAL_COL_LINEff=0x0
CFG_MARGINS_COL_LINEfg=0x424142
CFG_MARGINS_COL_LINEbg=0xC0C0C0
CFG_MARGINS_COL_LINEff=0x0
CFG_TRUNCATION_COL_LINEfg=0x4A4DCE
CFG_TRUNCATION_COL_LINEbg=0xFF
CFG_TRUNCATION_COL_LINEff=0x0
« Last Edit: June 05, 2008, 07:09:30 AM by Ding Zhaojie »
Ding Zhaojie
  • Hero Points: 37
Re: Color schemes
« Reply #18 on: June 05, 2008, 07:10:42 AM »
Dark Pastels (port from NetBeans)
[Dark Pastels]
CFG_COMMENTfg=0x84A6A6
CFG_COMMENTbg=0x22160D
CFG_COMMENTff=0x0
CFG_CLINEfg=0xFFCC99
CFG_CLINEbg=0x5A3E25
CFG_CLINEff=0x0
CFG_CURSORfg=0x211408
CFG_CURSORbg=0xFFCC99
CFG_CURSORff=0x0
CFG_NOSAVE_LINEfg=0x2C0F00
CFG_NOSAVE_LINEbg=0x2C0F00
CFG_INSERTED_LINEfg=0xFFFFFF
CFG_INSERTED_LINEbg=0x808040
CFG_KEYWORDfg=0xFF9900
CFG_KEYWORDbg=0x22160D
CFG_KEYWORDff=0x1
CFG_LINENUMfg=0xFFFFFF
CFG_LINENUMbg=0x22160D
CFG_LINENUMff=0x1
CFG_LINEPREFIXAREAfg=0xFFFFFF
CFG_LINEPREFIXAREAbg=0x22160D
CFG_MESSAGEff=0x0
CFG_MODIFIED_LINEfg=0xFFFFFF
CFG_MODIFIED_LINEbg=0x80
CFG_NUMBERfg=0xFF99
CFG_NUMBERbg=0x22160D
CFG_NUMBERff=0x1
CFG_PPKEYWORDfg=0x9A00
CFG_PPKEYWORDbg=0x22160D
CFG_PPKEYWORDff=0x1
CFG_SELECTED_CLINEfg=0xFFFFFF
CFG_SELECTED_CLINEbg=0x7D684E
CFG_SELECTIONfg=0xFFFFFF
CFG_SELECTIONbg=0x7D684E
CFG_SELECTIONff=0x0
CFG_STATUSff=0x0
CFG_STRINGfg=0x9CFF9C
CFG_STRINGbg=0x22160D
CFG_STRINGff=0x1
CFG_WINDOW_TEXTfg=0xFFCC99
CFG_WINDOW_TEXTbg=0x22160D
CFG_SYMBOL1fg=0xFFFF00
CFG_SYMBOL1bg=0x441F00
CFG_SYMBOL1ff=0x1
CFG_SYMBOL2fg=0xFFFFFF
CFG_SYMBOL2bg=0x441F00
CFG_SYMBOL2ff=0x1
CFG_SYMBOL3fg=0xFFFFFF
CFG_SYMBOL3bg=0x441F00
CFG_SYMBOL3ff=0x1
CFG_SYMBOL4fg=0xFFFF
CFG_SYMBOL4bg=0x441F00
CFG_SYMBOL4ff=0x1
CFG_FUNCTIONfg=0xFFFFFF
CFG_FUNCTIONbg=0x22160D
CFG_FUNCTIONff=0x1
CFG_FILENAMEfg=0xFFFFFF
CFG_FILENAMEbg=0x5A3E25
CFG_FILENAMEff=0x1
CFG_HILIGHTfg=0x22160D
CFG_HILIGHTbg=0xFFCC99
CFG_HILIGHTff=0x1
CFG_ATTRIBUTEfg=0xFFFFFF
CFG_ATTRIBUTEbg=0x22160D
CFG_ATTRIBUTEff=0x1
CFG_UNKNOWNXMLELEMENTfg=0x66FFCC
CFG_UNKNOWNXMLELEMENTbg=0x22160D
CFG_XHTMLELEMENTINXSLfg=0xCBFF
CFG_XHTMLELEMENTINXSLbg=0x22160D
CFG_PUNCTUATIONfg=0xFFFFFF
CFG_PUNCTUATIONbg=0x22160D
CFG_LIBRARY_SYMBOLfg=0xFFFFFF
CFG_LIBRARY_SYMBOLbg=0x22160D
CFG_OPERATORfg=0xFFFFFF
CFG_OPERATORbg=0x22160D
CFG_OPERATORff=0x1
CFG_USER_DEFINEDfg=0xFFFFFF
CFG_USER_DEFINEDbg=0x22160D
CFG_SPECIALCHARSfg=0xC6A68C
CFG_SPECIALCHARSbg=0x22160D
CFG_SPECIALCHARSff=0x1
CFG_HEX_MODE_COLORfg=0xFFFFFF
CFG_HEX_MODE_COLORbg=0x441F00
CFG_BLOCK_MATCHINGfg=0xFFFFFF
CFG_BLOCK_MATCHINGbg=0x413631
CFG_INC_SEARCH_CURRENTfg=0xFFFFFF
CFG_INC_SEARCH_CURRENTbg=0x7D684E
CFG_INC_SEARCH_CURRENTff=0x0
CFG_INC_SEARCH_MATCHfg=0xFFFFFF
CFG_INC_SEARCH_MATCHbg=0x6F5638
CFG_INC_SEARCH_MATCHff=0x0
CFG_CURRENT_LINE_BOXfg=0xB8B8B8
CFG_CURRENT_LINE_BOXbg=0xFF8080
CFG_PREFIX_AREA_LINEfg=0xB8B8B8
CFG_PREFIX_AREA_LINEbg=0xB8B8B8
CFG_VERTICAL_COL_LINEfg=0x5A3E25
CFG_VERTICAL_COL_LINEbg=0xFF8080
CFG_MARGINS_COL_LINEfg=0x5A3E25
CFG_MARGINS_COL_LINEbg=0x808080
CFG_TRUNCATION_COL_LINEfg=0x80
CFG_SYMBOL_HIGHLIGHTfg=0xFFFFFF
CFG_SYMBOL_HIGHLIGHTbg=0x6F5638
CFG_SYMBOL_HIGHLIGHTff=0x0
chrisant
  • Hero Points: 131
Re: Color schemes
« Reply #19 on: June 05, 2008, 07:30:53 PM »
Thanks for the schemes, Ding.
And the font, too.
pdebonte
Re: Color schemes
« Reply #20 on: June 16, 2010, 04:24:45 PM »
Hi,
Does anyone have any color schemes that match the plain-old defaults for the editors SlickEdit emulates, e.g. Visual Studio or VIM?  I'm surprised that SlickEdit "emulation" doesn't include the colors schemes.
-Pete
  • Hero Points: 522
Re: Color schemes
« Reply #21 on: June 16, 2010, 04:52:44 PM »
That is a good idea, While I can't promise that when we'll get around to it, I'll file a feature request for color schemes for specific emulations.
Wanderer
  • Hero Points: 23
Re: Color schemes
« Reply #22 on: June 16, 2010, 06:23:45 PM »
I would like to see the VS2010 default color scheme in SlickEdit.  It would make switching back and forth between the two editors much more comfortable.
MindprisM
  • Hero Points: 8
Re: Color schemes
« Reply #23 on: August 15, 2010, 08:23:07 AM »
Oh dear, I must join in this fun -- you all will like my font  ;)
donws
Re: Color schemes
« Reply #24 on: March 20, 2012, 01:16:24 PM »
Does anyone happen to have a Solarized color scheme to share?
http://ethanschoonover.com/solarized
Don
Gered
Re: Color schemes
« Reply #25 on: March 20, 2012, 04:37:16 PM »
Mine is based off of the Visual Studio style WekeRoad Ink. Just some slight changes here and there. The font pictured is Dina. Also, I've attached my Symbol Coloring scheme since I couldn't quite match the original Visual Studio style without it.
gamey
Re: Color schemes
« Reply #26 on: March 28, 2012, 06:15:32 PM »
Don
This theme looks right up my alley, especially the dark one.  I'd love to use this if anyone posts it.
cycloptic
Re: Color schemes
« Reply #27 on: March 28, 2012, 09:19:56 PM »
Don
Below is my attempt at creating a solarized theme. There are two here, one light and one dark.
cycloptic
[Solarized Dark]
VERSION=20
ASSOCIATED_SYMBOL_SCHEME=(None)
CFG_SELECTIONfg=0x969483
CFG_SELECTIONbg=0x423607
CFG_SELECTIONff=0x0
CFG_SELECTIONem=0x63510A
CFG_WINDOW_TEXTfg=0x969483
CFG_WINDOW_TEXTbg=0x362B00
CFG_WINDOW_TEXTem=0x1A1400
CFG_CLINEfg=0xFFFFFF
CFG_CLINEbg=0x605030
CFG_CLINEff=0x0
CFG_CLINEem=0x908060
CFG_SELECTED_CLINEbg=0x80C400
CFG_SELECTED_CLINEem=0x509400
CFG_MESSAGEff=0x0
CFG_STATUSbg=0xFFFFFF
CFG_STATUSff=0x0
CFG_CURSORfg=0x0
CFG_CURSORbg=0xE8E8C0
CFG_CURSORff=0x0
CFG_CURSORem=0xB8B890
CFG_MODIFIED_LINEbg=0xFF
CFG_MODIFIED_LINEff=0x0
CFG_MODIFIED_LINEem=0xCF
CFG_INSERTED_LINEff=0x0
CFG_INSERTED_LINEem=0x3030B0
CFG_KEYWORDfg=0x1689B5
CFG_KEYWORDbg=0x362B00
CFG_KEYWORDff=0x2000
CFG_KEYWORDem=0x1A1400
CFG_LINENUMfg=0x969483
CFG_LINENUMbg=0x423607
CFG_LINENUMff=0x0
CFG_LINENUMem=0x303030
CFG_NUMBERfg=0x98A12A
CFG_NUMBERbg=0x362B00
CFG_NUMBERff=0x2000
CFG_NUMBERem=0x1A1400
CFG_STRINGfg=0x98A12A
CFG_STRINGbg=0x362B00
CFG_STRINGff=0x2000
CFG_STRINGem=0x1A1400
CFG_COMMENTfg=0x756E58
CFG_COMMENTbg=0x362B00
CFG_COMMENTff=0x2000
CFG_COMMENTem=0x1A1400
CFG_PPKEYWORDfg=0x8236D3
CFG_PPKEYWORDbg=0x362B00
CFG_PPKEYWORDff=0x2001
CFG_PPKEYWORDem=0x1A1400
CFG_PUNCTUATIONfg=0x969483
CFG_PUNCTUATIONbg=0x362B00
CFG_PUNCTUATIONff=0x2000
CFG_PUNCTUATIONem=0x1A1400
CFG_LIBRARY_SYMBOLfg=0xC0C000
CFG_LIBRARY_SYMBOLbg=0x362B00
CFG_LIBRARY_SYMBOLff=0x2000
CFG_LIBRARY_SYMBOLem=0x1A1400
CFG_OPERATORfg=0x969483
CFG_OPERATORbg=0x362B00
CFG_OPERATORff=0x2000
CFG_OPERATORem=0x1A1400
CFG_USER_DEFINEDbg=0x362B00
CFG_USER_DEFINEDff=0x2000
CFG_USER_DEFINEDem=0x1A1400
CFG_IMAGINARY_LINEfg=0xFFFFFF
CFG_IMAGINARY_LINEbg=0xFF0000
CFG_IMAGINARY_LINEff=0x0
CFG_IMAGINARY_LINEem=0xCF0000
CFG_FUNCTIONfg=0xDB8B26
CFG_FUNCTIONbg=0x362B00
CFG_FUNCTIONff=0x2001
CFG_FUNCTIONem=0x1A1400
CFG_LINEPREFIXAREAfg=0xA1A193
CFG_LINEPREFIXAREAbg=0x423607
CFG_LINEPREFIXAREAff=0x1
CFG_FILENAMEfg=0x0
CFG_FILENAMEbg=0xFFFF00
CFG_FILENAMEff=0x0
CFG_FILENAMEem=0xCFCF00
CFG_HILIGHTfg=0xFFFFFF
CFG_HILIGHTbg=0x808000
CFG_HILIGHTff=0x0
CFG_HILIGHTem=0x505000
CFG_ATTRIBUTEfg=0x9985
CFG_ATTRIBUTEbg=0x362B00
CFG_ATTRIBUTEff=0x2001
CFG_ATTRIBUTEem=0x1A1400
CFG_UNKNOWNXMLELEMENTfg=0x2F32DC
CFG_UNKNOWNXMLELEMENTbg=0x362B00
CFG_UNKNOWNXMLELEMENTff=0x2001
CFG_UNKNOWNXMLELEMENTem=0x1A1400
CFG_XHTMLELEMENTINXSLfg=0x80FF
CFG_XHTMLELEMENTINXSLbg=0x362B00
CFG_XHTMLELEMENTINXSLff=0x2001
CFG_XHTMLELEMENTINXSLem=0x1A1400
CFG_SPECIALCHARSfg=0xC0C0C0
CFG_SPECIALCHARSbg=0xFFFFFF
CFG_SPECIALCHARSem=0xCFCFCF
CFG_CURRENT_LINE_BOXfg=0xFF8080
CFG_VERTICAL_COL_LINEfg=0x8080FF
CFG_VERTICAL_COL_LINEbg=0x8080FF
CFG_MARGINS_COL_LINEfg=0x808080
CFG_TRUNCATION_COL_LINEfg=0xFF
CFG_PREFIX_AREA_LINEfg=0x808080
CFG_PREFIX_AREA_LINEbg=0x808080
CFG_BLOCK_MATCHINGbg=0xFF0000
CFG_BLOCK_MATCHINGff=0x0
CFG_BLOCK_MATCHINGem=0xCF0000
CFG_INC_SEARCH_CURRENTfg=0x0
CFG_INC_SEARCH_CURRENTbg=0xFFFF80
CFG_INC_SEARCH_CURRENTem=0xCFCF50
CFG_INC_SEARCH_MATCHfg=0x0
CFG_INC_SEARCH_MATCHbg=0x80FFFF
CFG_INC_SEARCH_MATCHem=0x50CFCF
CFG_HEX_MODE_COLORfg=0x80
CFG_HEX_MODE_COLORbg=0xF0F0F0
CFG_HEX_MODE_COLORff=0x1
CFG_HEX_MODE_COLORem=0xC0C0C0
CFG_SYMBOL_HIGHLIGHTfg=0xFF0000
CFG_SYMBOL_HIGHLIGHTbg=0x362B00
CFG_SYMBOL_HIGHLIGHTff=0x2000
CFG_SYMBOL_HIGHLIGHTem=0x1A1400
CFG_MODIFIED_FILE_TABfg=0xFF
CFG_MODIFIED_FILE_TABbg=0xFFFFFF
CFG_MODIFIED_FILE_TABff=0x0
CFG_LINE_COMMENTfg=0x756E58
CFG_LINE_COMMENTbg=0x362B00
CFG_LINE_COMMENTff=0x2000
CFG_LINE_COMMENTem=0x1A1400
CFG_DOCUMENTATIONfg=0x756E58
CFG_DOCUMENTATIONbg=0x362B00
CFG_DOCUMENTATIONff=0x2000
CFG_DOCUMENTATIONem=0x1A1400
CFG_DOC_KEYWORDfg=0x756E58
CFG_DOC_KEYWORDbg=0x362B00
CFG_DOC_KEYWORDff=0x2001
CFG_DOC_KEYWORDem=0x1A1400
CFG_DOC_PUNCTUATIONfg=0x756E58
CFG_DOC_PUNCTUATIONbg=0x362B00
CFG_DOC_PUNCTUATIONff=0x2001
CFG_DOC_PUNCTUATIONem=0x1A1400
CFG_DOC_ATTRIBUTEfg=0x756E58
CFG_DOC_ATTRIBUTEbg=0x362B00
CFG_DOC_ATTRIBUTEff=0x2001
CFG_DOC_ATTRIBUTEem=0x1A1400
CFG_DOC_ATTR_VALUEfg=0x756E58
CFG_DOC_ATTR_VALUEbg=0x362B00
CFG_DOC_ATTR_VALUEff=0x2000
CFG_DOC_ATTR_VALUEem=0x1A1400
CFG_IDENTIFIERfg=0x969483
CFG_IDENTIFIERbg=0x362B00
CFG_IDENTIFIERff=0x2000
CFG_IDENTIFIERem=0x1A1400
CFG_FLOATING_NUMBERfg=0x98A12A
CFG_FLOATING_NUMBERbg=0x362B00
CFG_FLOATING_NUMBERff=0x2000
CFG_FLOATING_NUMBERem=0x1A1400
CFG_HEX_NUMBERfg=0x98A12A
CFG_HEX_NUMBERbg=0x362B00
CFG_HEX_NUMBERff=0x2000
CFG_HEX_NUMBERem=0x1A1400
CFG_SINGLEQUOTED_STRINGfg=0x98A12A
CFG_SINGLEQUOTED_STRINGbg=0x362B00
CFG_SINGLEQUOTED_STRINGff=0x2000
CFG_SINGLEQUOTED_STRINGem=0x1A1400
CFG_BACKQUOTED_STRINGfg=0x98A12A
CFG_BACKQUOTED_STRINGbg=0x362B00
CFG_BACKQUOTED_STRINGff=0x2000
CFG_BACKQUOTED_STRINGem=0x1A1400
CFG_UNTERMINATED_STRINGfg=0x98A12A
CFG_UNTERMINATED_STRINGbg=0x362B00
CFG_UNTERMINATED_STRINGff=0x2000
CFG_UNTERMINATED_STRINGem=0x1A1400
CFG_INACTIVE_CODEfg=0x756E58
CFG_INACTIVE_CODEbg=0x362B00
CFG_INACTIVE_CODEff=0x2000
CFG_INACTIVE_CODEem=0x1A1400
CFG_INACTIVE_KEYWORDfg=0x756E58
CFG_INACTIVE_KEYWORDbg=0x362B00
CFG_INACTIVE_KEYWORDff=0x2001
CFG_INACTIVE_KEYWORDem=0x1A1400
CFG_IMAGINARY_SPACEfg=0xFFFFFF
CFG_IMAGINARY_SPACEbg=0xFF0000
CFG_IMAGINARY_SPACEff=0x0
CFG_IMAGINARY_SPACEem=0xCF0000
CFG_INACTIVE_COMMENTfg=0x756E58
CFG_INACTIVE_COMMENTbg=0x362B00
CFG_INACTIVE_COMMENTff=0x2002
CFG_INACTIVE_COMMENTem=0x1A1400
CFG_MODIFIED_ITEMfg=0xFF
CFG_MODIFIED_ITEMbg=0xFFFFFF
CFG_MODIFIED_ITEMff=0x0
CFG_NAVHINTfg=0x80FF
CFG_NAVHINTbg=0x403010
CFG_NAVHINTff=0x0
[Solarized Light]
VERSION=20
CFG_SELECTIONbg=0xD5E8EE
CFG_SELECTIONff=0x0
CFG_SELECTIONem=0xCAEAE2
CFG_WINDOW_TEXTfg=0x837B65
CFG_WINDOW_TEXTbg=0xE3F6FD
CFG_WINDOW_TEXTem=0xFEFEFE
CFG_CLINEfg=0x969483
CFG_CLINEbg=0xD5E8EE
CFG_CLINEff=0x0
CFG_CLINEem=0xD5EEE8
CFG_SELECTED_CLINEfg=0x969483
CFG_SELECTED_CLINEbg=0xB6D6E2
CFG_SELECTED_CLINEem=0xB6E9E2
CFG_MESSAGEff=0x0
CFG_STATUSff=0x0
CFG_CURSORfg=0x0
CFG_CURSORff=0x0
CFG_KEYWORDbg=0xE3F6FD
CFG_KEYWORDff=0x2001
CFG_KEYWORDem=0xFEFEFE
CFG_LINENUMbg=0xD5E8EE
CFG_LINENUMff=0x0
CFG_NUMBERbg=0xE3F6FD
CFG_NUMBERff=0x2000
CFG_NUMBERem=0xFEFEFE
CFG_STRINGbg=0xE3F6FD
CFG_STRINGff=0x2000
CFG_STRINGem=0xFEFEFE
CFG_COMMENTfg=0xA1A193
CFG_COMMENTbg=0xE3F6FD
CFG_COMMENTem=0xFEFEFE
CFG_PPKEYWORDbg=0xE3F6FD
CFG_PPKEYWORDem=0xFEFEFE
CFG_PUNCTUATIONbg=0xE3F6FD
CFG_PUNCTUATIONem=0xFEFEFE
CFG_LIBRARY_SYMBOLfg=0x837B65
CFG_LIBRARY_SYMBOLbg=0xE3F6FD
CFG_LIBRARY_SYMBOLff=0x2001
CFG_LIBRARY_SYMBOLem=0xFEFEFE
CFG_OPERATORbg=0xE3F6FD
CFG_OPERATORem=0xFEFEFE
CFG_USER_DEFINEDbg=0xE3F6FD
CFG_USER_DEFINEDem=0xFEFEFE
CFG_FUNCTIONbg=0xE3F6FD
CFG_FUNCTIONem=0xFEFEFE
CFG_LINEPREFIXAREAfg=0x837B65
CFG_LINEPREFIXAREAbg=0xD5E8EE
CFG_FILENAMEfg=0x0
CFG_FILENAMEff=0x0
CFG_HILIGHTff=0x0
CFG_ATTRIBUTEbg=0xE3F6FD
CFG_ATTRIBUTEem=0xFEFEFE
CFG_UNKNOWNXMLELEMENTbg=0xE3F6FD
CFG_UNKNOWNXMLELEMENTem=0xFEFEFE
CFG_XHTMLELEMENTINXSLbg=0xE3F6FD
CFG_XHTMLELEMENTINXSLem=0xFEFEFE
CFG_SPECIALCHARSfg=0x837B65
CFG_SYMBOL_HIGHLIGHTbg=0xE3F6FD
CFG_SYMBOL_HIGHLIGHTem=0xFEFEFE
CFG_LINE_COMMENTfg=0xA1A193
CFG_LINE_COMMENTbg=0xE3F6FD
CFG_LINE_COMMENTem=0xFEFEFE
CFG_DOCUMENTATIONfg=0xA1A193
CFG_DOCUMENTATIONbg=0xE3F6FD
CFG_DOCUMENTATIONem=0xFEFEFE
CFG_DOC_KEYWORDfg=0xA1A193
CFG_DOC_KEYWORDbg=0xE3F6FD
CFG_DOC_KEYWORDem=0xFEFEFE
CFG_DOC_PUNCTUATIONfg=0xA1A193
CFG_DOC_PUNCTUATIONbg=0xE3F6FD
CFG_DOC_PUNCTUATIONem=0xFEFEFE
CFG_DOC_ATTRIBUTEfg=0xA1A193
CFG_DOC_ATTRIBUTEbg=0xE3F6FD
CFG_DOC_ATTRIBUTEem=0xFEFEFE
CFG_DOC_ATTR_VALUEfg=0xA1A193
CFG_DOC_ATTR_VALUEbg=0xE3F6FD
CFG_DOC_ATTR_VALUEem=0xFEFEFE
CFG_IDENTIFIERbg=0xE3F6FD
CFG_IDENTIFIERem=0xFEFEFE
CFG_FLOATING_NUMBERbg=0xE3F6FD
CFG_FLOATING_NUMBERem=0xFEFEFE
CFG_HEX_NUMBERbg=0xE3F6FD
CFG_HEX_NUMBERem=0xFEFEFE
CFG_SINGLEQUOTED_STRINGbg=0xE3F6FD
CFG_SINGLEQUOTED_STRINGem=0xFEFEFE
CFG_BACKQUOTED_STRINGbg=0xE3F6FD
CFG_BACKQUOTED_STRINGem=0xFEFEFE
CFG_UNTERMINATED_STRINGbg=0xE3F6FD
CFG_UNTERMINATED_STRINGem=0xFEFEFE
CFG_INACTIVE_CODEfg=0xA1A193
CFG_INACTIVE_CODEbg=0xE3F6FD
CFG_INACTIVE_CODEem=0xFEFEFE
CFG_INACTIVE_KEYWORDfg=0xA1A193
CFG_INACTIVE_KEYWORDbg=0xE3F6FD
CFG_INACTIVE_KEYWORDem=0xFEFEFE
CFG_INACTIVE_COMMENTfg=0xA1A193
CFG_INACTIVE_COMMENTbg=0xE3F6FD
CFG_INACTIVE_COMMENTem=0xFEFEFE
CFG_NAVHINTff=0x0
suck007
  • Hero Points: 3
Re: Color schemes
« Reply #28 on: December 25, 2012, 08:11:34 AM »
