Author Topic: How to get selection in a _str variable?  (Read 8208 times)
slickMS
« on: January 31, 2011, 05:09:02 PM »
Hi,
Can anyone show me how I can get the current section into a _str variable?
If possible this would work regardless of the type of selection, single-line, multiline
etc.
I use the following; code but this does NOT work when the selection spans more
than line?
static _str GetSelectionOrWordAtCursor()
  int first_col, last_col, buf_id;
  _str word, line;
  if (!_begin_select_compare() && !_end_select_compare())
  {  /* get text out of selection */
    _get_selinfo(first_col, last_col, buf_id);
    get_line(line);
    if (_select_type('', 'I'))
      ++last_col;
    if (_select_type() == 'LINE')
      word = line;
    else
      word = expand_tabs(line, first_col, last_col - first_col);
    _deselect();
  else
    deselect();
    word = cur_word(first_col, '', 1);
  return word;
Mark
« Last Edit: January 31, 2011, 07:29:00 PM by slickMS »
  • Hero Points: 292
Re: How to get selection in a _str variable?
« Reply #1 on: January 31, 2011, 09:07:12 PM »
@slickMS: The original function is not intended to handle normal selections spanning mult. lines.
But you might use the example below to add this feature to your version.
Good luck, HS2
 * retrieves selected text, first and last line number of an existing normal or line selection
 * @param seltext    [out] selected text if any
 * @param bline      [out] line number begin of selection
 * @param eline      [out] line number end of selection
 * @param doDeselect [in]  clear current selection [default: true]
 * @return  0  -> OK
 *          TEXT_NOT_SELECTED_RC
static int hs2_get_sel_text( _str &seltext, int &bline, int &eline, boolean doDeselect = true )
   int rc = TEXT_NOT_SELECTED_RC;
   seltext = '';
   if ( select_active() )
      typeless p; _save_pos2( p );
      long bpos, epos;
      _begin_select( '', false, true);
      bline = p_RLine; bpos = _QROffset();
      _end_select( '', false, true);
      eline = p_RLine; epos = _QROffset();
      _restore_pos2( p );
      if ( doDeselect ) deselect();   // optionally quit selection for convenience
      rc = 0;
      // say("bpos: " bpos " epos: " epos);
      seltext = get_text( (int)(epos - bpos), (int)bpos );
   return rc;
slickMS
« Reply #2 on: January 31, 2011, 09:21:19 PM »
Great!
Thanks; hs2. That seems to work fine!
MS
AGodfrey
« Reply #3 on: April 27, 2017, 09:03:30 PM »
Just a note for others who hit the problem I did: This technique doesn't work in a command that specifies VSARG2_REQUIRES_EDITORCTL.
'bline' ends up wrong, and is the same value as 'eline'. I don't know why this is; for me, VSARG2_REQUIRES_EDITORCTL was just a nice-to-have that I could do without.
  • Hero Points: 210
« Reply #4 on: April 28, 2017, 12:12:45 AM »
Use both: VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL
I'm not sure why.
See https://community.slickedit.com/index.php/topic,13314.msg52764.html#msg52764
