Author Topic: excluding .git directories  (Read 4082 times)
flethuseo
« on: April 04, 2014, 03:58:32 PM »
Hi all,
What regular expression do I use to omit all .git subdirectories. I can do so successfully for the current directory, but can't get it to do it for all subdirectories (recursively).
Ted
  • Hero Points: 347
Re: excluding .git directories
« Reply #1 on: April 05, 2014, 12:44:16 AM »
You forgot to say what operation you were trying to do.
If it's find in files then the help file says
Exclude - Paths, files, or file types can be excluded from a multi-file search by specifying them with wildcards or full path names. To specify multiple patterns, separate them with semicolons (colons on UNIX). No files are searched in a path that is excluded, including any files in sub-directories beneath. See examples of exclude patterns, below.
So *.git* should exclude any path with .git in its name.  If it doesn't work you could report it to SlickEdit Inc and maybe get a hotfix.
  • Hero Points: 210
« Reply #2 on: April 07, 2014, 07:41:38 PM »
For excluding subdirectories, I use the syntax "name\"
So, in FindAndReplace, I use something like this for exclusion:
    *.o;.git\;*.exe
This also works in "add tree" for a project.
I don't think Slick supports "*" or other patterns for directory exclusions.
See here: http://community.slickedit.com/index.php/topic,9190.msg39202.html#msg39202
flethuseo
« Reply #3 on: April 09, 2014, 05:31:45 PM »
Yes, I forgot to specify where.. I meant on the Project properties, add tree. I was adding the .git part incorrectly something like this **/*.git*, but .git\ worked fine.
